99 Dakota woodpecker sound
Old May 20, 2012 | 06:11 PM
ryan macg's Avatar
ryan macg
Default 99 Dakota woodpecker sound
Here goes my first post but I have used these forums to discover previous problems.
So I have 99 Dakota sport 4x4 with a 5.2 auto, and it has started making a very weird noise, only does it in neutral and drive, doesn't matter if it's in 2wd or 4x4 it still does it, but after it warms up it seems to go away in neutral but it's still there in drive, doesn't do it in reverse or park and it sounds to me like it's coming from the transmission, it sounds like a frigging woodpecker under there, and it speeds up when you accelerate, fluids are all where they should be
It doesn't seem to effect shifting or anything at all but man it sure is annoying and terrible sounding so any help would be very appreciated
I'll take a video o it here in a little bit an post it so you can hopefully help me out
Thanks
Ryan
Old May 20, 2012 | 08:12 PM
ryan macg's Avatar
ryan macg
Here's a link to the sound it makes
http://www.youtube.com/watch?v=RW71U...e_gdata_player
Old May 20, 2012 | 09:30 PM
Xxaler's Avatar
Xxaler
That's definitely not good... Get the pan off and see what kind of shavings you have in there.
Old May 21, 2012 | 06:01 AM
JBs DAK's Avatar
JBs DAK
I think it's a U-joint or, a convertor bolt has backed out.
Old May 21, 2012 | 09:37 AM
jondakotaguy's Avatar
jondakotaguy
Any shimmy, shaking, gitter, shudder/lurch of the truck when it in drive? Try from a stop and creep along with out hitting the gas.. is there anything strange going on?
Old May 21, 2012 | 10:17 AM
crateampsrock's Avatar
crateampsrock
id have a tranny shop have a look at it... Its not metallic enough to be a converter bolt, and a u-joint is more of a clunk then a tap...
Old May 21, 2012 | 12:08 PM
98DAKAZ's Avatar
98DAKAZ
I would get it looked at ASAP before something explodes and cost you big $$$$
Old May 21, 2012 | 01:27 PM
ryan macg's Avatar
ryan macg
It does tend to lurch and shift from d to r or r to d a bit clunky, but it has done that since I've owned it now and this noise hasn't seemed to effect performance in any way but I am very concerned about it
Thanks for the help though guys, I'm glad I finally decided to register to this group as I have this 99 and a 04 quad cab
