A/C wonky? Help its 93 this whole week!
Old Jun 20, 2012 | 03:35 PM
  #21
98DAKAZ's Avatar
98DAKAZ
Exclamation At home never worked for me
If you have good water pressure give it a try what can you lose?
Warm to cool is probably best even though I have done it hot before just took it easy if she is real hot just last time she was hot when I did it but my engine is all cast iron not aluminum with aluminum you should do it cool or warm just barely warm aluminum warps all too easy.
So my advice is cool to Luke warm with aluminum heads or blocks
Old Jul 17, 2012 | 04:47 PM
  #22
Dakota Greg's Avatar
Dakota Greg
Hey just thought Id revive this thread to help you all, I fixed it. I couldnt find a leak but knew there had to be one somewhere, so I took crisco and used it on every connector, it fixed the problem.
I noticed some white paste on the controller as a sealant it reminded me of cricso, so I got everything I could, from the break booster to the vac tank, to the numerous connections in the dash,
Be warned though, theres sharp metal in the dash I got cut pretty good.
Old Jul 17, 2012 | 05:31 PM
  #23
98DAKAZ's Avatar
98DAKAZ
Talking Now thats funny
Now that’s funny whatever it takes
I think what you wanted was called white lithium grease
Old Jul 17, 2012 | 07:33 PM
  #24
00DakDan's Avatar
00DakDan
Section Moderator
Crisco?
It must smell like french fries on a hot day.
Old Jul 17, 2012 | 08:40 PM
  #25
Dakota Greg
Ah, the real stuff, white lithium grease, im gona pick some up and just keep it in the garage.
And dear lord I hope not about the smell, my dad works all day making fries, if he smells that hes probably gona make me sell it sooner then I want.
Next project, heater core bypass. Thats after I get it back from the shop, Im having the valve cover gaskets replaced. They were leaking so much oil I was adding a quart every 400 miles.
