unknown plug under bench seat
Old Jun 24, 2012 | 07:15 PM
Jonnymoon5's Avatar
Jonnymoon5
Default unknown plug under bench seat
what is the plug marked 87921-h under the center console used for? it's a plug that's not plugged into anything and I may use it for a fuse block for my new console.
thanks
-jm5
Old Jun 29, 2012 | 07:49 AM
EricBing's Avatar
EricBing
does it have heated glass, rear window, heated mirrors??, i got heated mirrors and a replacement back window thats no longer heated (prev owner), that could be it
Old Jun 29, 2012 | 08:59 AM
McNasy's Avatar
McNasy
my truck has a power outlet and a dome light in the console, if yours does not, maybe thats it. mine is constant battery.
Old Jun 29, 2012 | 10:04 AM
bwdakrt's Avatar
bwdakrt
It's going to be for one of 2 things...power outlet in a console or a power connector for a power bucket seat. Red with tan stripe would be the power outlet...black with pink stripe should be for the seat.
Old Jul 2, 2012 | 10:16 PM
Jonnymoon5's Avatar
Jonnymoon5
It is a red and tan wire. so does that mean it would be fused to the cig lighter fuse? i'm thinking of connecting a fuse block to this wire to hold LED lights and possibly (probably) a siren, CB, and scanner?
Old Jul 3, 2012 | 02:16 AM
bwdakrt's Avatar
bwdakrt
The fuses for the power outlets is on the backside of the fuse block inside the cab on the drivers side. You have to lay on your back in the floor and look above the emergency brake pedal. 20 amp fuse IIRC.
Old Jul 3, 2012 | 03:29 PM
Jonnymoon5's Avatar
Jonnymoon5
couldn't find any fuses on the back of the fuse panel above the e-brake. I only saw that little box that all the wires went into that didn't look like there were any fuses in it.
Old Jul 3, 2012 | 04:34 PM
McNasy's Avatar
McNasy
i know i dont have any fuses on the back side of my fuse panel.
