HELP PLEASE!!!! dash and tail lights dont work
Old Jun 25, 2012 | 08:56 PM
MikeCzipri's Avatar
MikeCzipri
Default HELP PLEASE!!!! dash and tail lights dont work
2004 Dakota 3.7 V6 72k miles
All of the sudden my dash lights and tail lights stopped working. Searched the web, seems to be a common dodge problem but I cant find a solution.
Just 2 days ago, resistor plug for my AC melted and shorted, so that had to be replaced....wouldnt surprise me if this was another POS dodge electrical connector melting...but I have no idea.
I CHECKED ALL FUSES.....they all seem fine. Ideas?
Old Jun 25, 2012 | 09:46 PM
MikeCzipri's Avatar
MikeCzipri
Ok update....I found a fuse that was blown, #4 in the inside drivers side fuse panel...20A fuse....replaced it, the tail and dash lights turned on (but tail lights were dim) and then fuse popped....now right side blinker/ tail light doesn't work....repeated twice...fuse keeps popping....any clue wtf is going on?
Old Jun 25, 2012 | 10:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
Sounds like a short.
Have you been getting a lot of rain from Debby? Maybe water got into a connection.
Wish I had more for you.
Old Jun 25, 2012 | 11:45 PM
MikeCzipri's Avatar
MikeCzipri
Yes, as a matter of fact, it's been raining the past 3 days non stop. Is there a way to narrow down my search for the short? I'm thinking start in the rear tail light/ trailer hitch area?
Old Jun 26, 2012 | 09:47 AM
00DakDan's Avatar
00DakDan
Section Moderator
That's where I'd start too.
Old Jun 26, 2012 | 10:44 AM
gertie240's Avatar
gertie240
did you check the headlight switch? can you get a hold of a circuit breaker that matchs the fuse? a couple of years ago i had to build a few for a wiring problem i was having
Old Jun 26, 2012 | 09:36 PM
moe7404's Avatar
moe7404
all so check the ignition switch. mine shuts off the dash lights on mine. all so the turn sig swicth has most if not all the electrics going to the rear.
