Missing Air Conditioning System
Old Jul 6, 2012 | 10:25 AM
mmguy18's Avatar
mmguy18
If you have U-PULL junkyard that would be your best. If you have no existing system if you find a truck that has a complete system you could snag everything off of it. Sort of one stop shopping
Old Jul 6, 2012 | 01:07 PM
98DAKAZ's Avatar
98DAKAZ
Default just remember
just remember your Dakota is a 1998 so stick with the years 1996 to 1999 to find the corect parts for your year Dakota thay changed the A/C around 2000 you dont want anything after 2000 it will not work in your Dak.
To pull you will need some special tools to disconect the lines like these
http://www.qualitydist.net/wil-w83148.html
https://www.boocoo.com/auction/detai...78&refsrc=gshp
Old Jul 6, 2012 | 02:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
2000 should work. 2001+ is the problem, they went electric on the actuators.
I'd personally stick to a '98 if you can though. It just makes it that much easier.
Most u-pulls should have an "interchange manual" to tell you what will/won't work.
