A/c plug wire color 2000 Dakota
What color is the A/c plug wire to the compressor.. Had the engine swapped awhile back and cant find the plug for the a/c to power the compressor . thinking maybe the replacement motor harness didnt have ac?? or is the wire in there somewhere cause the plugs not... looking for a direction togo on what wiresa to hunt down.
Ok I will look at my wires but I replaced my connector last year and if I remember they were both just black the new connector from the dealer both wires were green.
So dont know if I can help but I will look.
Ok I looked at a friends 2005 with the same motor. I have power to my clutch. His truck doesn't have a plug going to the compressor. Seems its just a valve to allow the freon to flow? If I put a toggle switch onit can I just leave it powered when I'm using the AC. The 05 didn't have nothing inline. Just the clutch power which I have
I wouldn't recommend that. There are pressure switches wired in the system. A low pressure and a high pressure switch I am not sure on a 05 but I think it also needs to engage the e-fan. If you build to much pressure in the system it will blow out the safety plug on the compressor and leak out all your freon.
Trending Topics
i hope this will help,
.2001 dak factory service manual, paper. A/C compressor clutch relay ( in pdc ) connector 87, c3 18 db/bk wire coming out of realy. connector C106, wire c3 18 db/bk, going into into A/C COMPRESSOR CLUTCH. wire going out of clutch z1 18 bk. going to connector G105, into 8w015-2. connector 87 is IN relay. i know it is detailed but i didnt want to leave any thing out.
This is what I have its an old pic I took they both look to be green with a white strip on them hard to see the one but I think I see white.
Remember my truck is a 1998
Just found this looks like (LG/WT) is light green with a white stripe the other says (LG) this I guess is light green
Just noticed the light green is for the 4.7 Take note
