Air Resonator Box sensor?
Old Jul 23, 2012 | 11:15 AM
markk96's Avatar
markk96
Default Air Resonator Box sensor?
I have tried to do a search, but not much luck, what is the sensor that is inside the Air Resonator Box that sits on top of the engine on a 2003 Dakota 4.7?
Old Jul 23, 2012 | 11:44 AM
McNasy's Avatar
McNasy
can you be more specific or post a pic? im not sure what a resonator box is. are you talking about the box that comes from the filter and goes to the throttle body? if so, there is no sensor in it.
Old Jul 23, 2012 | 11:46 AM
markk96's Avatar
markk96
Yes Correct the box that sits on top of the throttle body, to take it off I have to remove the wire clip that is connected to a sensor, when I flip it over, you can see the sensor, it is long, and has a couple of wires on it. I did not think my truck had a Mass Air Flow Sensor, but now I am not sure.
I will get a picture tonight when I get off work.
Old Jul 23, 2012 | 01:32 PM
McNasy's Avatar
McNasy
ok cool. i am in the midle of changing my plugs as i type here. so i have the "hat" off the TB. i have no plugs going to mine. post when you can. im sure someone else will chime in by then.
Old Aug 20, 2012 | 10:57 AM
markk96's Avatar
markk96
I replaced my ignition coils and plugs this weekend, so I got a change to take the box off, and here is a picture of the sensor. What is it?
Old Aug 20, 2012 | 10:59 AM
magnethead's Avatar
magnethead
Looks like IAT to me. Def a thermistor on the end.
Old Aug 20, 2012 | 11:10 AM
98DAKAZ's Avatar
98DAKAZ
Default Emission : Air Temperature Sensor
Old Aug 20, 2012 | 09:33 PM
markk96's Avatar
markk96
Thanks, that explains it.
Old Aug 20, 2012 | 09:59 PM
00DakDan's Avatar
00DakDan
Section Moderator
Interesting. There are no wires on my resonator either.
Looks like they moved it from the plenum.
