tap tap tap
Old Jul 29, 2012 | 03:20 PM
92n04dakota's Avatar
92n04dakota
Default tap tap tap
OK so ive been having this problem for quite some time, i have the 4.7 and when i start it up i have a really bad tapping sound, but once it has been started and warmed for like 3 minutes the sound goes away, ive had a rod knock on a previous vehicle before and this sounds nothing like it, im just wondering if anyone had had a problem like this before or maybe knows whats wrong.
thanks for all feedback in advance
Old Jul 29, 2012 | 03:42 PM
RYCOMA79's Avatar
RYCOMA79
exhaust leak when it warms up metal expands seals leak
Old Jul 29, 2012 | 06:33 PM
Dakota Greg's Avatar
Dakota Greg
Heres a trick, take a long 18" + screwdriver and use it like a sound carrier, put your ear on the handle, make sure they are solid hard plastic or wood, soft grip ones dont work. Places to check : Waterpump, AC, alternator, valve covers.
Also you dont have to worry about a rod knock on the 4.7 overhead cam engines dont have rods.
Old Jul 29, 2012 | 07:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Actually Greg, you do.
A rod knock is caused by the connecting rods, crankshaft to piston, not the pushrods.
Old Jul 29, 2012 | 08:28 PM
92n04dakota
OK so a few guys i know have told me the exhaust but where would that leak be?
Old Jul 29, 2012 | 08:55 PM
EricBing's Avatar
EricBing
MIne was rear of the exhaust manifold drivers side, exhaust manifold gaskets are known to leak on these..bad news is exhaust manifold warpage is sometimes the culprit
Old Jul 31, 2012 | 02:36 AM
Dakota Greg
Learn something new every day
Old Oct 1, 2019 | 05:26 PM
Aaron H's Avatar
Aaron H
You’re absolutely right
Old Oct 1, 2019 | 06:14 PM
Dodgevity's Avatar
Dodgevity
Good on you for letting him know. He's been waiting since 2012.
