Whining under hood...water pump?
Hey everyone. I had a whine in my engine a month back and got the serpentine belt replaced. That fixed the problem, but now I'm hearing another whine while idling. I was told that the water pump had some play to it. Would that make a whining sound?
2000
3.9 v6 2wd. Has 73k on it
2000
Just had my waterpump done in January, cost me $400 at a good shop.
Wasn't tackling it in the winter time but its nice now (atleast where I live) so I'd say try it if you have a weekend to yourself.
If not, $900 is way too much.
Check your power steering fluid too, mine was whining because it was a little low.
Trending Topics
Water pump is not hard to change even if you have never done it. Get a Haynes manual and will take it through it step by step. Manual around 20 bucks water pump 40 bucks. Also check Power steering pump and Alternator. Usually the bearings go bad on the Water pump and you will hear a grinding sort of noise.
