Relay or Drivers window switch??
Old Aug 7, 2012 | 10:28 PM
luap2011's Avatar
luap2011
Default Relay or Drivers window switch??
Recently bought my 2000 dodge dakota slt quad cab, and knew about a problem with the power windows & locks. So pretty much the driver switches will only roll down driver & passenger windows, won't roll down the rear ones, and won't lock the doors. Can roll down the window from passengers switch, but can't lock doors. Rear door window switches won't roll down the windows. So my question is can this all stem from a bad driver window switch or should I check into the relay switches under the hood??
Old Aug 8, 2012 | 10:57 AM
luap2011's Avatar
luap2011
Anybody? Lol. Just want to know whether I should buy a switch or get a couple new relays and try that
Old Aug 8, 2012 | 11:24 AM
00DakDan's Avatar
00DakDan
Section Moderator
There are no relays for the windows, and the only one for the locks is in the PCM. It's all door switches with the master being the drivers.
It does control everything and is often the source of frustration. Drinks/rain/whatever gets dropped into it.
You can download a wiring diagram from the "stickies." It may help you chase some wires if you want.
