want to upgrade to bigget tires.. do i need more lift?
Old Aug 8, 2012 | 07:25 PM
localmotion0426's Avatar
localmotion0426
Default want to upgrade to bigget tires.. do i need more lift?
I was wondering, I have a 2000 dakota sport club cab4x4 with the 3.9L. My question is can I upgrade from 32/11.50/r15 to 33/12.50/r15 with out any editing? I already have 3in worth of body lift...
-tyler
Old Aug 8, 2012 | 11:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Dakota section.
Old Aug 8, 2012 | 11:58 PM
magnethead's Avatar
magnethead
with a 3 body lift, I think 33x12.5 should be the very edge. I think you'll have a bigger issue with tires rubbing the frame at full steer.
My opinion- it's 1/2" taller on top of the tire and 1/2" wider at each sidewall. Put your hand on top of your 32, this is where the new tire will be. Check for clearance. Steer full left. Can you fit your hand between frame and left tire, bumper/sway bar and right tire? Same for steering right- bumper/sway bar and left front, chassis and right front.
Old Aug 9, 2012 | 04:15 AM
Blaze10's Avatar
Blaze10
You'll fit 33s my 99 Dakota has only 3inch body lift with 33" mt tires agressive tread. Grabs onto mud flaps that's all . My 04 I have 35s but they chew on the frame more then I'd like.
