Power Steering Pulley Problem
Old Aug 10, 2012 | 09:08 PM
DrewS287's Avatar
DrewS287
Exclamation Power Steering Pulley Problem
I have a 2004 Dodge Dakota 3.7L V6.
I recently had the power steering pump replaced. I was driving and I heard the serpentine belt whining. Opened the hood and the belt was not on the PS pulley and the pulley was separating from the pump.
I got the belt back on the pulley, but the bolt that holds the PS pulley on the pump is gone. It must have came loose while I was driving.
Auto parts stores can't order it, only the pulley. Same with the Dodge dealership. The pulley doesn't come with the bolt/nut that secures the pulley onto the pump, and I can't find it anywhere.
Any help would be greatly appreciated. I can't drive the truck until I find it.
Old Aug 10, 2012 | 11:35 PM
00DakDan's Avatar
00DakDan
Section Moderator
There's always a boneyard if you can't find it elsewhere. It might be your best option.
Old Aug 11, 2012 | 05:25 PM
98DAKAZ's Avatar
98DAKAZ
Default go here
Go here input your truck look under engine.
http://www.wholesalemopar.com/
Call them and ask they have been very helpful to me over the phone 1-800-428-0517
Old Aug 11, 2012 | 09:39 PM
DrewS287's Avatar
DrewS287
Default Thanks
To those who replied, thank you. Fellow Dakota owners might find this interesting/helpful.
The power steering pulley actually isn't secured to the pump with a bolt (that's why I couldn't find it). The pulley slides on the pump with a pulley puller (like this:
Amazon Amazon
But the pump has to be off in order to change out the pulley.
If you ever run into a PS pulley problem, now you'll know.
Old Aug 11, 2012 | 10:07 PM
98DAKAZ's Avatar
98DAKAZ
Talking Ok
Ok now I understand what you were looking for yes that’s how it’s done so the pressed on pulley came off?
How did that happen it shouldn’t of happened and never does that’s why I was thinking about something completely different.
This is where a picture or two would of helped tremendously
Old Aug 11, 2012 | 10:46 PM
DrewS287's Avatar
DrewS287
It was actually a faulty pump that caused the pulley to come off. I had the pump replaced and it was bad, which caused the pulley to come loose.
By the way, I have a brand new pulley from Mopar that I ended not needing if anyone wants it.
