Headlight Issue
Hey, I haven't posted here before, but I figured I'd give it a shot.
Firstly, I have looked all over the place both on Dodge Forums and the WWW for people who are having similar issues, I haven't been able to find any that are quite the same. So I'll explain.
I have a 1997 Dodge Dakota SLT V8 5.2L.
My low-beams do not turn on. I have checked the plugs to the headlights, they're receiving power, and not receiving power with the headlight switch on/off respectively. I replaced the headlights, thinking "Oh, they're just dead" (Truck purchased last week), but, nope. They still don't work, and I'm at a loss.
The Haynes book, and some other sources on the internet suggest that it could be my daytime running lights module, I haven't tested this yet, I wanted to check here, first.
Another issue (that I'm not sure if it's related or not) is that the high-beam switch won't lock on. However high-beams will work if the switch is held.
Other info: Parking lights work, reverse works, signal works..
So, if anyone's had this, and knows how to fix it: Please help!
However the low-beam headlight switch is a completely other switch, located to the left on the dash. This controls the headlights and cargo lights. I have pulled that switch out and tested it, everything seems fine. Sorry for not clarifying better.
The multi-function switch (high/low beam) switch does not "stay" in place, like some Ford's do. It just "clicks" and goes back to position, toggling high/low beam.
It does sound like you need to replace the switch.
Got a multi-function switch off a 1999 Dakota, will put that in tonight and see how that goes.
