2001 Dakota Sport
Old Aug 14, 2012 | 05:09 PM
waygin1's Avatar
waygin1
Angry 2001 Dakota Sport Ashtray
I have a problem with my ash tray and need to remove and replace it. The problem is that I don't see what holds it in. Does any one know how to remove it?
Old Aug 14, 2012 | 05:46 PM
User's Avatar
User
Just the tray or the whole assembly?
They tray removed by squeezing the 2 sides and pulling out, assembly is screwed in at the bottom/back.
Old Aug 14, 2012 | 07:25 PM
magnethead's Avatar
magnethead
Mine is broke too. I just have it shoved up and pinned under the dash bezel.
Old Aug 14, 2012 | 08:01 PM
waygin1's Avatar
waygin1
Angry 2001 Dodge Dakota Sport Ashtray
It looks like that the cover is broke, so I am looking at taking out the assembly to check it over and replace it if nessary.
Old Aug 14, 2012 | 08:09 PM
magnethead's Avatar
magnethead
on mine, the cover broke off the tray, and the hinges on the tray broke. I didn't try squeezing it out. I'm hoping I can use that spot for a small gauge pod or something using a replacement tray- That way it's stealth. Wanting to add vacuum, oil pres, water temp, and trans temp gauges. I know I can't fit 4 gauges there, but it'd at least help. Really all I need for racing is water temp and trans temp. Even then, the Mk8 fan keeps water pretty much between 180 and 190, so trans temp is all I need. And I know I can fit 1 gauge in the ash tray.
Old Aug 14, 2012 | 09:08 PM
waygin1's Avatar
waygin1
I just went out and could not spot any screws in the bottom of the ashtray.
Old Aug 14, 2012 | 09:59 PM
User's Avatar
User
You will have to remove the actual tray part first before you can remove the screws.
I'm not at home otherwise I would get photos.
Old Aug 14, 2012 | 10:17 PM
waygin1's Avatar
waygin1
OK but my tray is just hanging thre by the wires to the lighter and I haven't been able to get it unplugged. but I will go out and try again.
Old Aug 14, 2012 | 10:24 PM
magnethead's Avatar
magnethead
i think wires pulled straight out on mine
Old Aug 16, 2012 | 12:10 AM
waygin1's Avatar
waygin1
Smile 2001 Dodge Dakota Sport Ashtray
I finally got the wirea loose (there was a lock). So the cover is off now and has one of the lower hinge hooks broke. Now I need to find one. It looks like the Dakota and Durango might use the same part. Thanks to every one for your help.
