2000 Dakota 4.7 revs high when started cold....
Old Aug 17, 2012 | 07:00 AM
Cectek's Avatar
Cectek
Default 2000 Dakota 4.7 revs high when started cold....
Hello from Norway!
My Dakota 4.7 have started to act strange when started cold.
It revs immedelity up to 2000-2500 rpms.
After a little touch on the throttle it goes down to normal rpm.
Have anyone experienced this??
Could it be the TPS?
Regards Kjetil
Old Aug 18, 2012 | 11:22 AM
hanleysh's Avatar
hanleysh
Sounds like a high idle setting to help warm it up
Old Aug 18, 2012 | 12:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
When did you clean the throttle body last? It may be a sticking IAC.
Old Aug 20, 2012 | 12:55 AM
mmguy18's Avatar
mmguy18
Idle Control Valve
Old Aug 20, 2012 | 03:34 PM
Cectek's Avatar
Cectek
Hi!
Problem fixed!
After cleaning both the IAT and the Idle Air control valve.
Both needed cleaning.
Thanks!
Kjetil
