4.7 Idling issues
Old Aug 20, 2012 | 12:31 AM
DakotaGuy95's Avatar
DakotaGuy95
Default 4.7 Idling issues
When it first starts, it idles really high. Then later, it will idle up and down. What could it be? It does need the exhaust fixed, it has a few leaks. Any ideas?
Old Aug 20, 2012 | 12:45 AM
mmguy18's Avatar
mmguy18
Try checking Idle Control Valve.
Old Aug 20, 2012 | 02:10 AM
moparman_2004's Avatar
moparman_2004
if you havnt cleaned your throttle body out pull off everything and scrub the **** out of it this will fix most 4.7l idle issues
Old Aug 22, 2012 | 12:18 AM
GreenDak22's Avatar
GreenDak22
Might have to replace the throttle position sensor
Old Oct 14, 2012 | 12:52 PM
hdhigh90's Avatar
hdhigh90
changed #3 plug. now it idles at 1500 rpm. any sugesstions on how to fix this problem?
Old Oct 14, 2012 | 01:11 PM
rwilhelms's Avatar
rwilhelms
I had the same problem I took my throttle body off and cleaned it real good. I also changed my IAC sensor because my truck would idle all over and eventually get down so low it would die sometimes. Since doing this I havent had any issues.
Old Oct 14, 2012 | 01:23 PM
hdhigh90's Avatar
hdhigh90
Default 2003 dodge ram 1500, idles too high, after changing spark plug.
2003 dodge ram idles too high after changing spark plug #3.
Old Oct 16, 2012 | 09:40 PM
mmguy18's Avatar
mmguy18
You would be amazed on the junk you will have the other side of the throttle body. Take it off and clean real good.
