unknown Dakota issue
Old Sep 9, 2012 | 05:26 PM
BlackBeast69's Avatar
BlackBeast69
Default unknown Dakota issue
I have a 98 5.2 and since I bought it 2 months ago its been having this issue. So ill be driving down the road and out of nowhere it will start to slow down and start bucking, when I let my foot off the gas it will stop but its started to happen more frequently and im not sure what it could be. I also smell an odd smell when i shut the truck off. Smells like burning brakes but richer. I also put on a new y pipe with a high flow cat. Im not a mechanic but could it be a fuel filter? Comments would be greatly appreciated thanks.
Old Sep 9, 2012 | 05:35 PM
98DAKAZ's Avatar
98DAKAZ
Could be a number of things
First thought is PCM the computer that was what my Dakota did as the PCM was going out
Or
The smell of brakes may mean brakes locking up
Gas problem possible
Old Sep 9, 2012 | 05:43 PM
BlackBeast69
Im pretty sure its not a break issue, they seem fine, it also idles high sometimes, how could check and see if the pcm has gone bad?
Old Sep 9, 2012 | 05:52 PM
98DAKAZ's Avatar
98DAKAZ
That I’m not sure
My Dakota started to buck surge, idle high then low just acted like some possessed demon was inside of it.
I guess have an auto store put a scope on it to check for error codes first they do it for free usually like Autozone.
Did you buy any cheap gas last time bad gas could do this also
If I remember my Dakota had a strange smell also
Old Sep 9, 2012 | 06:01 PM
BlackBeast69
Its not throwing any codes, I just started putting mid grade in my truck on Friday so well see how that works. But yea thats pretty much how it acts lol.
Old Sep 9, 2012 | 06:05 PM
98DAKAZ's Avatar
98DAKAZ
Question
Your new exhaust is not getting plugged up some how is it?
Old Sep 9, 2012 | 06:20 PM
BlackBeast69
It sounds fine it does baffle alot when i let off the gas.
Old Sep 9, 2012 | 06:25 PM
98DAKAZ's Avatar
98DAKAZ
Question
I wonder if some how you are getting too much back pressure in the exhaust system I don’t see how being as it’s supposed to be getting your exhaust gasses out faster.
But worth thinking about you never know?
Or maybe its screwing up your O2 sensors some how but I would think some kind of error code would show for that
Old Sep 9, 2012 | 06:49 PM
UWAdventurer's Avatar
UWAdventurer
If you think it is a fuel problem run some good fuel system cleaner or Seafoam through the fuel system a couple of times. How long after you start driving does it start having problems.
Old Sep 9, 2012 | 07:35 PM
BlackBeast69
Its always different, sometimes it wont even buck, I have a stock air filter is it possible that it could have disrupted the fuel air ratio
