TPS Wires chewed
I'm kind of a newb, so go easy on me please...
I have a 1997 Dakota SLT 3.9L v6. It has very low miles (43k) as it was owned by my wife's late grandfather. When he passed away 6 years ago, we bought it from her grandmother. They used it as a spare vehicle and I use it to drive to work, which is about 2 miles from home.
Anyways, Over the last year, I've had a string of problems rise up. My dash cluster stopped working (Gauges don't work, and all the lights at the bottom stay on). In the process of trying to figure out how to fix this, I discovered that I had a P0123 error. I went to check the voltage on the TPS (after watching some youtube vids to figure out where that is and how to test it), and noticed NO voltage. I went to unplug the harness and noticed the wires had been chewed completely through, flush with the wire cluster.
I am going to try to fix this, but needed some tips. Where do the TPS wires lead to? Is it easier to replace the whole thing, or should I TRY to splice the wires? I don't have much room to work with, so I'm hoping for an "easier" solution (though I'm not holding my breath). Any help in this would be MUCH appreciated. Thanks!
Originally Posted by Kevno6
they sell the tps wire and plug on rockauto.com check them out they have great prices.
Posted from Dodgeforum.com App for Android
Thanks for the link! So, where does the TPS wire connect to?
you would be shorting something out most likely. my wife got her grandpa's 98 dakota with thirty thousand on the clock. hers needed ball joints, grind and drill!!!
Trending Topics
Again, thanks for all your advice!
I wouldnt worry about the cluster just yet, get those wires up and then go from there. I have read a lot of posts about clusters freaking out and its usually a grounding issue or the PCM. find a yard yet? ZMAN goes about once a week, hit him up, maybe he can find those parts at his .
