New 2003 dakota, got some questions!
Subscribe
Sep 26, 2012 | 11:20 PM
Just picked up this 03 dakota extended cab 4x4.
Got a few questions such as :
which size tires can I put on? (needs new ones soon think they are 265-70-16 stock)
It has the 4.7 v8, how is it on gas? Anything to make it better for cheap?
Also wondering where I can find out certain packages that it has or doesn't have (like lsd rear, offroad package, 5 or 4 speed auto? )
Thanks!
Reply 0
Sep 26, 2012 | 11:39 PM
The 4.7 is pretty decent on gas, around 20 i think. As for specs and packages, you can email your VIN to Chrysler and they'll send you everything you want to know.
Posted from Dodgeforum.com App for Android
Reply 0
Sep 27, 2012 | 12:15 AM
Or you can go to your local dodge dealership and ask for a build sheet for your truck, all you'll need is your vin #. It will also tell you the stock tire size.
Reply 0
Sep 27, 2012 | 12:47 AM
Ok also how hard are the rear sway bar bushings, rear diff seal, and front seal to change? They all need to be done soon
Reply 0
Sep 27, 2012 | 01:15 PM
Sway bar bushings are easy. Do you mean the diff cover gasket?
Reply 0
Sep 27, 2012 | 08:18 PM
Well I was quoted $683 for front seal, rear pinion seal, service rear diff, both rear sway bar links and transmission service. Does this seem good?
Also who do I email the vin to get the original specs?
Reply 0
Sep 28, 2012 | 04:45 PM
Look for the Sticky post at the header of this page. Will give you some good info. One thing quite a few folks have done to help with MPG's is to remove the clutch fan.
Reply 0
Subscribe
