turbo or supercharger??
Turbo has greater potential, but would require at least some exhaust modification to make it worth it, plus you can change your boost much easier than with a supercharger. Superchargers are cool, but you'll have a lot of parasitic power loss since it is driven by the crank and not the exhaust like a turbo is.
Posted from Dodgeforum.com App for Android
Originally Posted by MoparMan1991
Quote:
Originally Posted by dolittle
Are you kidding with out rebuilding the eng and changing the compression of the the eng.
It is a wast of money.
Now you're just assuming his ride is all stock. Seeing as he didn't include details, it probably is, but to assume is to make an *** of u and me.
Coming from someone who's been there, done that, it's clear you need to do a lot more reading, the info is out there.
That said, I'm a turbo guy. But keep an eye out for the Kenne Bell upgrade kit coming soon http://zcodeperformance.com/index.html
I need to apologize to the OP. I see your engine is not stock. I would research the cost of doing both I think a turbo would be easier and cheaper (if you can get a kit for the engine) having said that your may get better HP with the mechanical supper charger.
Let us all know how it goes.
