Is this true?
I have a 2001 QC 4X4 4.7ltr when the weather get cooler say below 10C or 50F my tranny will not go into Overdrive until it warms up.
Is this a safety feature or do I have a issue not an issue in the summer it works fine.
no not normal. your internal fluid filter is clogged. i have had this happen in cold weather. on older trans like the old 727. would not go into rev. cause rev needs a lot more oil. ill bet the OD is the same way. do this change fluid and filter. here is a new thing. an external filter, go to auto zone get 2210 magna-fine filter. should be 3/8 tube, in the line returning to the trans, the line on the left side at the rear is the return line. use high pressure hose. the filter goes inline with the coolant return line. you will need to cut some tubing. i like this cause i think you will need fewer pan, internal filter changes.
I'll back Dakota Greg with this, he's right. The transmission won't shift into overdrive until it warms up and that is by design.
Many newer cars do this as well.
Trending Topics
So I'm not trying to thread jack but I have a somewhat related question. If the automatic transmission won't shift into o.d. untill its at a certain temp should I avoid putting my manual trans into overdrive before the truck is at a certain temp? Or is the manual trans able to handle o.d. right away
