2000 Dakota 4.7 cold start tick
Old Oct 29, 2012 | 08:47 AM
cgs1984's Avatar
cgs1984
Default 2000 Dakota 4.7 cold start tick
I'm having an issue with the famous 4.7l cold start tick/knock. Been searching for hours online and still not sure I found a fix worth trying. Truck has 243k on it and I know I can get 300k+ from the truck but this cold start issue is driving me nuts. I know it can't do alot of damage from what most people say but having 243k on the truck worries me. Truck is in good shape and drives good but I know there is alot of sludge in the oil fill cap and can't imagine whats inside the motor. Gonna check for broken head bolts and stuff today while I replace my tie rods anyway. But I also seen posts on putting some kerosene in the motor to "clean" it up, but was wondering if this is a no no beings my truck has 243k on it or is a no no altogether. Anyway, was looking for solid statments here as I spent to much time with this as it is so some help would be gratful.
Old Oct 29, 2012 | 11:53 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Oct 29, 2012 | 07:24 PM
RYCOMA79's Avatar
RYCOMA79
243k on it I would drive it till it dies. I mean that's a lot of kms. If you start messing with the sludge it could get ugly fast. check your valves and rocker arms for proper adjustment if that doesn't help leave it alone. just my opinion
Old Oct 30, 2012 | 02:26 AM
olsarge's Avatar
olsarge
Sludge in the oil fill tube is probablybecause of condensation from the PCV dumping in there. Not a problem if your oil is free of sludge at oil change. Check for exhaust header bolt or heat reflector shield bolt being broken and causing the tick noise.
Old Oct 30, 2012 | 08:09 AM
New 2 Dodge's Avatar
New 2 Dodge
243k... not sure if you are talking KMs or Miles. Mine has about 208,000kms and has the "tick". I used seafoam on mine but I don't think it yielded much in terms of results. I have read that the "sludge" on the oil cap is common - I have that as well. I would say for me, if it wasn't giving you any trouble than dont mess with it. My motor runs strong and I keep up with the oil changes. I've never gone into an engine not even removed valve covers - to me, you could just be looking for trouble.
Just my opinion.
Old Oct 30, 2012 | 11:12 AM
Trent479's Avatar
Trent479
I wouldnt mess with a motor with that many miles. The sludge probably holds it together and keeps compression haha thats some great news tho that its still kickin. Run it till it dies. Put some high miles oil in it next, mix some cleaner in with the gas, i wouldnt gp as far ad seafoam and you should be good. Have you looked at the pullys? Maybe they are dry.
Old Oct 31, 2012 | 01:50 PM
mmguy18's Avatar
mmguy18
How about a weak oil pump. Not getting oil pumping as quick as it use too
Old Oct 31, 2012 | 01:59 PM
98DAKAZ's Avatar
98DAKAZ
Lightbulb The safe way to de sludge
mmo will slowly melt out the sludge it will take about two or three years of mmo to slowly de sludge the engine.
mmo in the engine cylinders as a soak is a good way to get any stuck/locked up rings free again.
It’s a day or two process if you want I can give it to you?
