Build Sheet
Old Oct 31, 2012 | 01:36 PM
mmguy18's Avatar
mmguy18
Default Build Sheet
Had a previous post that required me to get a build sheet for my truck. Thought I would share if anyone was interested in what one looks like.
Thanks to 00DakDan
P9 Cloth 40/20/40 Split Bench Seat
-AZ Agate
ADAP Light Group
AGBP Tire and Handling Group
AGGP Sport Group
AGU Sport Plus Group
AJK Convenience Group
AJL Travler Group
AJPP Power Convenience Group
APAS Monotone Paint
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZP 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKES 9x2.5 HD Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CBVP Cloth Door Trim Panel w/Map Pocket
CCAS Under Seat Lighting
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CJTS Delete Front Center Seat
CKES Front Seat Area Carpet
CLA Front Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUNP Overhead Console
DGB All 4-Speed Automatic Transmissions
DG4S Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJDS 205MM Front Axle
DMH 3.92 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFD Rear Sliding Window
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GNTP Rear View Auto Dim Mirror
GT4 Power 6 X 9 Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXRP Keyless Entry
HAAP Air Conditioning
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KNSS STRIPE/BADGE/MOLDING/COLOR
KRSS STRIPE/BADGE/MOLDING/COLOR
KSSS STRIPE/BADGE/MOLDING/COLOR
KTSS STRIPE/BADGE/MOLDING/COLOR
K2CP STRIPE/BADGE/MOLDING/COLOR
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LCDP Map/Dome Reading Lamps
LDAP Underhood Lamp
LMBS Halogen Headlamps
LNJP Fog Lamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MBDS Argent Rear Bumper
MDA Front License Plate Bracket
MFNP Body Color Grille
MHAS Black Windshield Moldings
MLAP Body Color Fascias
NAE California Emissions
NBKS EVAP Control System
NBN Northeastern States Tracking
NBVP Low Emission Vehicle (LEV)
NFBS 22 Gallon Fuel Tank
NHMP Speed Control
PB3 Intense Blue Pearl Coat
QB3S Intense Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TUTP 31X10.5R15 OWL All Season Tires
TZAP Goodyear Brand Tires
WJ9P 15X8.0 Aluminum Wheels
XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications
Old Oct 31, 2012 | 01:52 PM
98DAKAZ's Avatar
98DAKAZ
Default Its a Canucky Dakota
I want to get this done were do you go to get it started?
I swear my Dakota is an oddball Dakota almost every part has made in Canada stamped on it.
Old Oct 31, 2012 | 02:09 PM
Niakon's Avatar
Niakon
It's actually very simple all you have to do is go to Dodge.com. Then go down to contact us, then send us an email. Just fill out the form and ask for a build sheet in the comments
Old Oct 31, 2012 | 02:11 PM
Niakon's Avatar
Niakon
Might as well post my build sheet, just for fun
Dark Slate Gray
Light Group
Heavy Duty Service Group
Trailer Tow Group
Convenience Group
Monotone Paint
4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
136 Amp Alternator
750 Amp Maintenance Free Battery
4 Wheel Disc Rr Anti-Lock Brakes
2nd Rear Bench 3 Pass/Fold Seat
Front Floor Mats
Center Armrest Storage
Delete Floor Console
All 5-Speed Automatic Transmissions
5-Spd Automatic 545RFE Transmission
3.55 Rear Axle Ratio
4.7L V8 MPI Engine
Rear Fixed Window
Rear View Day/Night Mirror
Power Mirrors
Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Route H1 - CP, Regina
200 KPH Primary Speedometer
Power Locks
STRIPE/BADGE/MOLDING COLOR
Glove Box Lamp
Front Reading/Map Lamps
Rear Dome w/On/Off Switch Lamp
Daytime Running Headlamps, High Beam
Fog Lamps
Cargo Lamp
CHMSL Lamp
Argent Rear Bumper
Bright Grille
Body Color Fascias
50 State Emissions
U.S. Emissions w/OBD 1
EVAP Control System
24 Gallon Fuel Tank
Power Steering Cooler
Engine Block Heater
Speed Control
Heavy Duty Engine Cooling
Next Generation Engine Controller
Bright Silver Metallic Clear Coat
AM/FM Compact Disc Radio w/Chgr Ctrl
4 Speakers
Tire Carrier Winch
P245/70R16 BSW On/Off Road Tires
Steel Spare Wheel
16X7.0 Cast Aluminum Wheels
Pickup Box
Class IV Receiver Hitch
7 Pin Wiring Harness
7 to 4 Pin Wiring Adaptor
English/USA Language
Brake/Park Interlock
Old Oct 31, 2012 | 03:12 PM
mmguy18's Avatar
mmguy18
You can also go under my post for keyless entry and look at the link 00DakDan has and take you there. They will need the last 8 on your vin #.
Old Oct 31, 2012 | 03:25 PM
dodgeramguy85's Avatar
dodgeramguy85
http://www.dodge.com/wccsapp/univers...ull&category=R
I should just keep that thing in my favorites. I post it up like 3 times a week.lol
Old Oct 31, 2012 | 04:31 PM
98DAKAZ's Avatar
98DAKAZ
Talking
Well I sent it off Thanks to all
Old Nov 28, 2012 | 10:50 PM
01dak3.9's Avatar
01dak3.9
On my build sheet it said delete front center seat but I still have the middle seat it has a 40/20/40 if that makes a difference. Why could that be. It also says under seat lighting. I have never noticed the lights and am wondering where they are under the seats.
Old Nov 28, 2012 | 11:46 PM
dodgeramguy85
Never ever heard of under seat lighting on daks. Maybe they mean the ones under the dash. As far as the seat it could of been switched out. Maybe the guy that ordered it didnt like it or it was changed when someone was going to buy it.
Old Nov 29, 2012 | 08:56 AM
jondakotaguy's Avatar
jondakotaguy
I did that a few weeks ago.. found the truck was in for service twice; called the dealership and found both window motors were replaced; painted and 24 point inspection; basically told me every leak the truck has and sending unit was bad.. (Stuff i already know about and already started fixing)...
Its funny how some of it was really simple and cheap to fix but the previous owner never fixed non of it.. LOL
