High pitch squeak, need help!
Old 11-06-2012, 09:33 PM
Blacknights's Avatar
Blacknights
Blacknights is offline
Default High pitch squeak, need help!
Okay so I have recently started hearing a squeak. I have generally located it. It happens per rotation of the front right wheel. Aside from a possible new wheel bearing is there anything that yall could advise this could be?
Old 11-06-2012, 09:36 PM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
Could be the u-joint on your front driveshaft.
Does it get louder as you speed up?
Old 11-06-2012, 09:52 PM
Blacknights
Not louder but more frequent, but when I apply the brakes it always stops. I will look at that though, any other suggestions are still greatly appreciated!!
Old 11-06-2012, 10:11 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
How are your brake pads?
Old 11-07-2012, 12:21 AM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
Check to see if the caliper is tight. They are notorious for stripping out. Mine would squeak when I would hit bumps but would stop when the brake was applied and it turns out that my bottom caliper bolt would not tighten. I drilled it out then heli-coiled it and it was fine
Old 11-07-2012, 06:38 AM
Blacknights
Okay so yall are generally thinking the same way as I am. I will note I did just install new rotors. So at this point the brakes is something I am going to get and have specfically looked at.
Quick Reply: High pitch squeak, need help!
