HELP! 2002 dodge dakota 4x4 problem
Old Nov 9, 2012 | 10:17 PM
lodz08's Avatar
lodz08
Default HELP! 2002 dodge dakota 4x4 problem
hi i have a 2002 dodge dakota 4.7. the other day i went to use the 4 wheel drive high it worked till i made a right turn and it knocked out of 4 wheel to 2wheel. Now when i drive the truck in 2 wheel i have a grinding knocking sound coming out of the front end at all speeds, i noticed today when i put it in 4 wheel high that anything over 25 miles the knocking goes away completly with a slight shake above 50 mph. also when i use 4 wheel low it works flawless i cant think of what it could possibly be i would apprectiate any advise
Thanks Chris
Old Dec 11, 2012 | 09:11 AM
Robbadodge's Avatar
Robbadodge
Hard to believe this was not answered.
Possibly due to where you posted it... under General Discussion. Post a new thread directly within the 2nd Gen page for better help.
Robb
Old Dec 11, 2012 | 07:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post into the proper forum.
Old Dec 11, 2012 | 07:59 PM
00DakDan's Avatar
00DakDan
Section Moderator
What transfer case do you have? Since you're saying 4 hi and 2 wheel I'm guessing it's the NV233.
It's not a full time 4wd transfer case. Were you need on a slippery surface.
Check your front driveshaft. It's not uncommon to have noise/vibration from a bad cv joint on the driveshaft.
Old Feb 27, 2013 | 10:09 PM
guggilodall's Avatar
guggilodall
I have an 04 Dakota SXT 4x4 and I brought it into the Dodge dealership because I had the same problem and they said I broke the CV joint on the front drive shaft..
