oversize brake pin replacement?
Old Nov 12, 2012 | 09:04 AM
Wes Garrett's Avatar
Wes Garrett
i had the same problem, my wheel bearing came apart on me while driving. had it towed, and fixed it, buw when i putting the caliper back on, the sliding stud, would thread in, but wouldnt torque down, so i said screw it and set up similar to a ford, just a nut an bolt system, i replaced with grade 8 and its been holding since.. 5 months of wheelin, daily driving, and trailer towing.
i drive Commercial with my dakota, so like the semi's in MASSACHUSETTS, on ANY commercial vehicle needs to have a daily inspection log book.. i have NEVER took my truck out of service for brake issues since i replaced the hardware
Old Nov 12, 2012 | 07:08 PM
magnethead's Avatar
magnethead
Well dad and I looked at it and couldn't find a bad bearing. It makes going going left but not right (so a right bearing), but the noise comes from the left. Dad thinks it's just tire noise.
Old Nov 12, 2012 | 07:09 PM
JohnnyCrash's Avatar
JohnnyCrash
The proper fix, weld the casting, install caliper, mark center on sliders, redrill and tap.
Helicoils work well in blind holes, not so well in open holes(removal is a problem)
Cheapest solution - buy new oversized pins.
easier solution, make a pin, drill to next over size and tap.
Old Nov 12, 2012 | 09:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
Rotate the tires and see if the noise changes.
