oversize brake pin replacement?
Old Nov 11, 2012 | 01:15 AM
magnethead's Avatar
magnethead
Default oversize brake pin replacement?
Sounds like my left front wheel bearing is ready to split in half. quite turning right, herd of elephants turning left. Pretty sure from the left front.
I have the oversize slide pins in the caliper from when I did the front brakes, they say only use once...what's the suitable fix other than a new upright?
Old Nov 11, 2012 | 11:15 AM
Tom A's Avatar
Tom A
Section Moderator
If I understand correctly, the fix would be a standard pin with a heli-coil.
Old Nov 11, 2012 | 12:19 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation
I think they are fine just keep using them unless they have come lose they are just sliders they dont take a lot of abuse.
Im a bit confused about what you are asking?
Old Nov 11, 2012 | 01:25 PM
Rakaric's Avatar
Rakaric
+1 Yes, that's what it was! I saw this thread last night and I was going to respond, but I completely forgot what this was called
Old Nov 11, 2012 | 03:23 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation
The thing I don’t like about heli-coil is if you don’t get the hole drilled straight or centered perfect then it’s off now and with the slider pin that could cause binding.
Who drills perfect by hand?
Old Nov 11, 2012 | 03:45 PM
Tom A's Avatar
Tom A
Section Moderator
It's pretty easy to drill straight when you're just slightly enlarging an existing hole. And isn't the other end of the pin supported? It's not like it can be crooked (just going by memory here, so I could be wrong).
Old Nov 11, 2012 | 04:15 PM
magnethead's Avatar
magnethead
I've heard standard + helicoil before, but what size helicoil? Is this something that the parts stores stock or ??
Old Nov 11, 2012 | 04:39 PM
Tom A's Avatar
Tom A
Section Moderator
I think it's something goofy like a 9mm, but a decent parts store should have it.
Old Nov 11, 2012 | 05:02 PM
magnethead's Avatar
magnethead
M9 x 1.25 right? (same as a standard M9 bolt..if I'd known that when we screwed them up, would have ran a bolt from the backside to fix the threads...screwed up the first 3 threads and couldnt find the tap, never thought to use a bolt)
How do the oversize pins effect helicoil fitment? I don't know how much bigger they are.
Old Nov 11, 2012 | 05:05 PM
Tom A's Avatar
Tom A
Section Moderator
I don't know about the oversize pins. I've never used one. But I doubt they enlarge the hole as much as you would need to for a helicoil.
