Best way to access fuel pump?
I have the classic fuel pressure leaksown issue on my 98 slt 4x4 with the 318...
I'm going to replace the fuel pump et all and my body thinks I should either pill the body or cut a hole In the bed rather then dropping the tank... What's every bodies feeling on this?
i got a 2000 base/sport 4x4 with the 3.9
Would have to agree with bed removal.Just had mine off to do some undercoating. 4 bolts each side, remove taillights, and undo filler neck. The fuel pump is right there no fuse no muse. 2 guys can lift it off.
I actuall say drop the tank. I say that though because on my 2002 quad cab, the fuel pump module is not completely accesible with the bed off - it's is partially under the cab. Either way is not very difficult but with the bed you need extra help unless you have chain falls or something to lift the bed off.
only reason i know that, is because im doing a resto...
https://dodgeforum.com/forum/2nd-gen...n-rebuild.html
Trending Topics
