Thermostat housing bolt size - HELP!
Old 11-22-2012, 07:13 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
Originally Posted by JackTheStripper5.9
So I guess I should go with an m8 thread insert....
That's what I would do. It's a common size and should be readily available.
BTW, did you try using a slightly longer bolt, just in case there are some good threads a little deeper in the hole?
Old 11-22-2012, 07:19 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Tom A Excellent idea sometimes that’s all you need 1/4 deep more good threads just snug it with some locktight and a gasket sealer
Old 11-22-2012, 07:43 PM
JackTheStripper5.9's Avatar
JackTheStripper5.9
JackTheStripper5.9 is offline
Havn't tried that but doesn't sound like too bad of an idea. I guess my first experiment is using a longer bolt. I just need to figure out what size he used for that since it's an SAE bolt. I'm assuming it's a 5/16 if the factory size is an m8.
Makes me wonder if tapping an m8 hole to a 5/16 is part of the problem....
Old 11-23-2012, 09:57 AM
JackTheStripper5.9
OK this sounds stupid but I observed that the factory holes were 5/16-18. The guy who tapped it out also used 5/16-18 BUT gave me an m8 bolt. WTF?
I have no idea how it went in fine the first time, but luckily the threads aren't too ****ed up. I just went to the hardware store and got another 5/16 bolt and it tightens down fine.
I also went and bought a new thermostat housing cause the old one was bitched up and some brush on gasket sealant. Hopefully this will serve me well.
Old 11-23-2012, 10:01 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Thumbs up
Just give the gasket sealer a 1/2 day to dry real good and I think you will be ok.
The cooling system is not under a lot of pressur anyway
Old 11-23-2012, 12:30 PM
JackTheStripper5.9
That actually didn't work, when I went to put the housing on (I test fitted it with the housing on) it still spun around. I used the longer bolt idea and it works. I got it just snug enough and it seems to hold a seal. I might of been able to go tighter but I was really nervous about stripping it more. That's why I used the gasket sealer. Like what was mentioned in the thread, let the sealant do the work.
Only problem now it finding the nut to hold my air filter on. D'oh! of all parts to lose...
Old 11-23-2012, 02:06 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
If this still pops open on you redo it with only gasket sealer no gasket the good sealer is like a glue the gasket may become the weak link metal to metal with the Blue or Black RTV Sealant may work better and maybe rough up the surfaces just a little bit not too much so it grips the surfaces better. and clean all grease off
I used the red RTV on my Diff cover and removing it took some prying it was glued on good and tight
Old 10-14-2021, 03:03 PM
Bub4506's Avatar
Bub4506
Bub4506 is offline
Default 2003 5.7 Hemi
The size is M8 x1.25 course thread.mine measures just a hair over 1inch thread length. Head is 13mm and I found mine at the local hardware store.
So the last time I did my intake, I broke off one of the thermostat housing bolts while removing it and had to have it drilled out. Was doing my thermostat again and when I went to install the housing, the threads stripped.
Does anyone know the thread size of the bolts? Google isn't being my friend today. Could only find info on the old style V8 and the 4.7s. I have a 5.2 Magnum.
Help would very much be appreciated so I can find the next size up and tap it out. My truck isn't doing me much good with coolant pissed out of the thermostat housing
Old 10-16-2021, 12:13 PM
volaredon's Avatar
volaredon
volaredon is offline
disagree. though 13mm is "close enough" every "5.2" (I hate that designation, still a 318 cid to me) I have ever touched has taken a 1/2" socket on those bolts. youre looking at 5/16-18 threads. all fasteners on that engine except for the wire nuts on teh alternator, and the bolts that hold the lines to the AC compressor, are standard. NOT METRIC. I cant say the same for the fasteners on the body/ frame. I hate metric, and I hate even more, vehicles that are a mix match. We all have GM to thank for that clusterf#@k idea.
PLEASE don't bastardize that engine! That said I have had to Heli coil a few thermostat bolt holes on these engines over the years.
Old 10-16-2021, 02:37 PM
Bub4506's Avatar
Bub4506
Bub4506 is offline
Default I Didn't say 5.2.......
imine is a 2003 3rd gen 5 7 hemi. And it is absolutely a metric bolt. Just posting to help other hemi owners.
Quick Reply: Thermostat housing bolt size - HELP!
