mpg
Old Nov 26, 2012 | 08:06 PM
dakotasport98's Avatar
dakotasport98
New Member
Default mpg
I have a 98 Dakota sport next cab 2wd with a 3.9L manual trains. I'm only getting like 11 MPG but the truck runs fine n starts OK. It a little fumey sometimes. Any help would be appreciated
Old Nov 27, 2012 | 02:03 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Probably a bad O2 sensor or a bad intake plenum gasket.
I will move this to the 2nd generation Dakota sub-forum.
Old Nov 28, 2012 | 03:59 AM
magnethead's Avatar
magnethead
11 city or 11 highway?
If the former, you're only 2 off the standard benchmark. If the latter....time for investigation.
Old Nov 28, 2012 | 01:13 PM
dodgeramguy85's Avatar
dodgeramguy85
When was the plugs,wires,cap and rotor replaced?
Old Nov 28, 2012 | 06:04 PM
dakotasport98
New Member
I changed the plugs and cap n button about a month ago.
I'm getting 11 MPG average.
how can I check the intake gasket?
The O2 Senor should turn on the light right.
Old Nov 28, 2012 | 07:45 PM
00DakDan's Avatar
00DakDan
Section Moderator
What thermostat do you have???
Old Nov 28, 2012 | 08:25 PM
JustinDD99's Avatar
JustinDD99
02 sensor wont always necesarily throw a check engine light.
Old Nov 28, 2012 | 09:07 PM
moe7404's Avatar
moe7404
get a new cap and rotor. and plug the vent hole in the cap, with JB-weld. thats how the moisture gets in. the rotor is a week point, it gets a week spot under the spring. if you look close you can see it.
Old Nov 28, 2012 | 09:50 PM
dodgeramguy85
What brand was the cap and stuff? Cheap stuff usually fails after a few month. Intake gasket can be checked by taking the air hat off the throttle body then use a flash light and open the butterfly's and look to see if you have oil laying in the bottom. A residue is ok but puddles is not.
Old Nov 29, 2012 | 08:59 AM
Robbadodge's Avatar
Robbadodge
Ditto here. Bad sensor does not always trigger the CEL. My OBDII always shows an error, but the CEL is never triggered.
