I'm in the same boat. I bought a set of Euro style one piece lights and it helped a bit but the damn things melted inside near the bulb on the reflector. I am considering some DEPO one piece clear lights now.
I can assure you that you will NOT be disappointed. Once you install the mounting brackets, make sure you also use a washer on the plastic mounting holes or else the screw will pull through the hole and make a headache for you. I learned this the hard way.
Is it the bottom hole on the core support? It looks as if the PO already had that happen.......
It will improve it some. Will you be able to tell a difference? That im not so sure about maybe a slight difference but will it help that much when on the road? I doubt it. They do this mod on rams because the power for the lights can sometimes melt the switch some guys said it helped some.
