Transmission I D
Old Dec 2, 2012 | 05:29 PM
Romas's Avatar
Romas
Default Transmission I D
Hi guys, I'm brand new on this Forum, and I'm looking for help. I own a 1998 Dodge Dakota Sport,2.5l, 5speed shift. Last night, after driving about an hour, suddenly I had major difficulty shifting. It didn't want to go into any gear. I left it in reverse and let it cool for an hour. I was able to get it home (7 miles) I can put it into any gear with the motor off, and then start the truck and let the clutch out. I think I need to change the trans. fluid. The mileage is 198k and I got it at about 130k. I don't know which tranny I have, whether it's the AX15 or the NV3500. Both use different fluid. Is there a quick way of finding out?
Old Dec 2, 2012 | 06:14 PM
Wes Garrett's Avatar
Wes Garrett
simplest way is to go here http://www.dodge.com/wccsapp/universal/D/index.jsp fill out the form.. ASK THEM FOR A BUILD SHEET. it will list exactly what transmission came in the vehicle (and everything else) at the time of build.
YOU WILL NEED YOUR VIN NUMBER. i did this 2 weeks ago, gave them the information they asked for, but also typed the FULL VIN number in the addition information section.
Old Dec 2, 2012 | 06:25 PM
00DakDan's Avatar
00DakDan
Section Moderator
You'll have the AX-15.
It could be your clutch. It's hydraulic and if it fails you will have trouble getting it into gear. Basically, it's probably not releasing all the way.
Old Dec 2, 2012 | 06:33 PM
dirtbiker's Avatar
dirtbiker
2.5 liter will have the ax15 behind it, as 00Dak stated.
