Exhaust pipe
I am looking at getting some information on putting my exhaust out of the side before the rear tire..only problem I have is the exhaust would hang to low..I'm thinking of cutting a hole on the side and running the system above the frame and through the hole..I've seen other guys do this with their Dakotas just wondering how would I cut a hole that big without damaging it? and is it a good idea?
Posted from Dodgeforum.com App for Android
Not sure what you mean. Unless you have a 3" body lift, running the exhaust above the frame means it will be inside your bed.
Probably best to run it out behind the tires, straight out the back, or turned down after the muffler(s). There's a reason you don't see what you're talking about on any other trucks.
![Talking](https://dodgeforum.com/forum/images/icons/icon10.gif)
If not using your bed for anything slap some of these in your truck.
http://www.supertruckusa.com/sb/Grand_Rock/PowerFlow_Stacks.htm
I have seen a Dakota with just one pipe up before
![](http://www.supertruckusa.com/sb/shared_images/Grand_Rock/Aussie%20on%20truck.jpg)
![](http://www.supertruckusa.com/sb/shared_images/Grand_Rock/mitre%20cut%20stacks%20small.jpg)
like this one
http://www.dodgedakotart.com/feature...sane_up3_3.jpg
Nice street Dak
Dont know on the pipes sorry I would check out the other Street Dakota forums not here http://www.dakotart.com/ or http://www.customdakotas.com/forums/
like this one
Trending Topics
