Project, need some help/advice
Old Dec 4, 2012 | 06:12 PM
Blacknights's Avatar
Blacknights
Default Project, need some help/advice
So I've been wanting a little bit of fun and so I've had an idea to run the truck on some nitro-methane.
Questions:
1) Can our trucks specifically the 4.7 and automatic transmission handle that?
2) How can I easily switch out what fuel I am using? I've thought of a Jerry can holding it and then running a line to the pump which leads to the next question
3) How can I get the fuel to the engine?
4) Where is our fuel pump located?
Also any idea how much power boost that'll be? 40-50 hp?
Old Dec 4, 2012 | 11:58 PM
dodgeramguy85's Avatar
dodgeramguy85
There could be a chance of melting/burning up a pistion. Is it really worth it to go through the hassle of doing all this work to have a chance in doing that? Buy a tuner,throttle body and cam then you can have reliable power
Old Dec 5, 2012 | 10:17 PM
Blacknights
Fastmans is great but I have to not have a truck for a week which right now. Not motorcycle season I can't really do that. As for a new cam any advice?? I feel like I have to replace my pistons soon anyways approaching 240000 miles. My baby is getting old and worn so I feel like a performance overhaul is in order.
Old Dec 6, 2012 | 12:27 AM
dodgeramguy85
Im not sure on cams as I never really looked into them. I know if you are gonna do all this work might as well redo the motor while you have it that far apart.
Old Dec 6, 2012 | 12:52 AM
magnethead's Avatar
magnethead
You're playing with fire, quite literally.
You will gain nothing from nitro with a low 9:1 comp street motor, you may actually lose some because the Stoich for methanol is very high and it's BTU is lower than gas.
To get a good meth/nitro mix, you're talking $20 a gallon or more (assuming you can buy nitro by the gallon, it's $1200 for a 44 gallon drum from VP and very few distributors will sell it by the gallon). Methanol is $130 for a 55 gal drum, and we go through a drum every 25 passes, if that tells you anything. M5 is $308 a drum and is 7% nitro pre-mix (3.8 gallons nitro to 51.2 gallons methanol).
Old Jan 13, 2013 | 10:06 PM
Blacknights
Okay, just curious, didn't really have anyone to ask the question to.
As for the fastman, my lucky day, went to the junkyard and found the only 4.7 in the whole place that still had a throttle body and got a spare. Next week I may order a fastman or I got access through a friend with a lift and may switch out my diffs to 3.92!!!
Old Jan 13, 2013 | 10:42 PM
magnethead's Avatar
magnethead
Being 4x4, you should have 3.92's?
What's your cruising RPM at 55 MPH and what size tire?
Old Jan 14, 2013 | 12:31 AM
Blacknights
Paperwork said 3.55s, @70 it is a hair over 2000 if I remember @55 I can't remember specifically but I think it is like 1600 or something, in overdrive it can 1300 @ 45ish.
Old Jan 14, 2013 | 12:51 AM
magnethead's Avatar
magnethead
I didnt know 3.55's shipped as a 4x4. News to me. But yes, those are 3.55 #'s. 3.92's would be near my 4.10's, 2K @ 60.
Old Jan 17, 2013 | 04:01 PM
Blacknights
On top of getting the fastman throttle body I am also hacking the transmission to switch it to the 545fre it actually it
And possibly switching to a SCT tuner, cause hands down everyone is recommending it over a superchip and I personally haven't gotten anything out of the superchip tune
