Flashing Headlights.
Old Dec 11, 2012 | 08:13 PM
Darrin031's Avatar
Darrin031
Default Flashing Headlights.
So first time poster here. Got a question for you fellas,
As i get up for work and such my 98 dakota sport runs just fine for about 5 minutes. After warming up for about 5 minutes my headlights and only my headlights will flash on and off.
I have tested my battery and my grounds. What else should i be trouble shooting to fix this annoying and dangerous issue.
Thanks ahead of time.
Old Dec 12, 2012 | 02:13 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a bad switch. It probably has an internal circuit breaker that is tripping when it gets overloaded. I'm not too sure if the 2nd gen has individual relays for the headlights to limit the power draw from the switch.
I will move this to the 2nd generation Dakota sub-forum.
Old Dec 12, 2012 | 02:15 AM
Jadam701's Avatar
Jadam701
I had a buddy with a 94 1500 that did that, he had a bad relay, couldn't tell you which one though.
Old Dec 12, 2012 | 02:20 AM
magnethead's Avatar
magnethead
this is from the 01 FSM.....
Old Dec 12, 2012 | 11:24 AM
00DakDan's Avatar
00DakDan
Section Moderator
I guarantee that the wiring diagram from '01 won't help him but it's a good idea.
Before '01 the headlights weren't run off the CTM, they were hardwired. I know they changed around '99 too but were still hardwired.
I don't have a '98 diagram but check the switch. Some do have breakers.
Old Dec 12, 2012 | 11:28 PM
magnethead's Avatar
magnethead
in that case, I'd go with breaker/weak fuse/relay.
Old Dec 13, 2012 | 01:48 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Old Dec 13, 2012 | 10:46 AM
X-Raycer's Avatar
X-Raycer
My money's on the bad Relay.
Old Dec 13, 2012 | 06:01 PM
Darrin031's Avatar
Darrin031
I appreciate all the diagrams and replies. You guys have helped me tremendously.
Old Dec 17, 2012 | 09:31 PM
baker45810's Avatar
baker45810
new member as of 12-15-12, just wanted to thank everyone for the heads up on flashing headlight problem on a 01 dakota. dealership price on a new ctm...257.00, salvage yard repalcement... 20.00, although I spent 2 hours looking and took it off the donor truck myself, what a deal! thanks to all and happy holidays!
