Dodge dakota tie downs
Old Dec 13, 2012 | 01:28 PM
magnethead's Avatar
magnethead
same here
Old Dec 13, 2012 | 02:37 PM
Robbadodge's Avatar
Robbadodge
Default Well now
I started to think it was Gen 1 in floor until mag chimed in.
OP is going to have to remove this liner and find them... else have a lot of holes
Old Dec 13, 2012 | 04:48 PM
magnethead's Avatar
magnethead
I thought all 2nd gen dak's had them in the floor.....unless it's of the dozen things changed between 99 and 00/01....no b/c dakaz is in the floor on his 98...as are mine in 01....but yours are on the side?
or maybe quads have them up high and single/ext cabs have them in floor?
Old Dec 13, 2012 | 07:28 PM
Dakotaquad's Avatar
Dakotaquad
well mine has the tie down hooks in the front and the rear of the truck but they r not in the floor they are about 4-5 inches above it.
Old Dec 16, 2012 | 02:05 PM
Robbadodge's Avatar
Robbadodge
Okay, QC on the sides and all others in the flloor?
Let's hear it, y'all! What do you have and where are yours? (loaded question)
Old Dec 16, 2012 | 05:11 PM
ahsnowlover's Avatar
ahsnowlover
I have a 99 club cab and I have two on the sides by the tail gate and two in the front on the floor but they are covered up by my tool box
Old Dec 16, 2012 | 05:19 PM
magnethead's Avatar
magnethead
That's what I'm going with. Can't say i know of any reasonable explanation as to why, though.
Old Dec 16, 2012 | 08:25 PM
Niakon's Avatar
Niakon
Mine is an 04 Quad cab. They are all on the side with front ones up high and back ones down low.
Old Dec 16, 2012 | 10:13 PM
Robbadodge's Avatar
Robbadodge
I'm going out of town for a few days. When I get back, I'll be removing my liner and checking the floor. Since I've never had it off, there may be some in the floor.
Maybe they're up to the installer of the hour. "Put the tie downs where you want, make it up as you go, just get them in there!"
Old Dec 17, 2012 | 04:56 PM
lambs's Avatar
lambs
My 97 has front ones in the floor and rear ones mounted on the side as in the pics someone posted.
The fronts are integrated into the floor drains, which drain towards the sides of the bed underneath. When you pull your liner, you need to check the drains for debris. They are easily cleaned out. Mine were packed with mulch, and there was also a fair amount of mulch under the liner.
I used a Dremel tool to enlarge the rear holes in the liner, and I put a nickel plated steel ring (1 1/2 inch) around each of the rear tie down points so they wouldn't be so hard to connect to. On the fronts, I made a loop out of plastic coated steel cable and ran it beneath the tie down posts. The loop of cable can be stuffed down into the drain if not needed and since it naturally wants to uncoil itself, it won't rattle down there. I connect the rear tie down rings with a bungee to keep them from rattling.
