2002 Dodge dakota help
Old Dec 12, 2012 | 07:34 PM
grizzmint's Avatar
grizzmint
Question 2002 Dodge dakota help
Hello, I am new to these forums. I recently purchased a 2002 dodge dakota sport with the 4.7 v-8. It keeps coming up with a check engine light and the code is p 0301, which is a cylinder 1 missfire. After having it hooked up to a missfire machine it shows several cylinders are missfiring. I have changed the spark plugs, swapped coil packs, put new fuel injecter in cylinder 1, changed oil, and had the cylinders checked. While driving it has no misfires, after shifting from park into drive the misfires start popping up. Any one have any advice. I have been to 6 different places and no one can figure out the problem.
Old Dec 12, 2012 | 08:43 PM
dino30's Avatar
dino30
need to check for a vacuum leak .. Intake or a hose .. the truck could be getting to much air from the wrong source causing the engine to miss ..when hooked to a vac gauge it should be between 17-20 inch's of mercury .. Any fluctuation or a lower unstable reading will indicate problems ..
Old Dec 12, 2012 | 08:53 PM
grizzmint's Avatar
grizzmint
I already had the truck tested for vacuum leaks. sorry i forgot to add that. everything is checking out fine. Any other ideas? Also thank you for the input
Old Dec 13, 2012 | 04:01 AM
highrevr/tflea's Avatar
highrevr/tflea
Did you clear the code? Unplug the battery?
Old Dec 13, 2012 | 08:48 PM
grizzmint's Avatar
grizzmint
Yes i have reset the light several time.
Old Dec 14, 2012 | 09:38 AM
00DakDan's Avatar
00DakDan
Section Moderator
What spark plugs are in the engine now?
How's the fuel pressure?
The cam/cranks sensors help set the ignition timing. I know you aren't showing a code for them but I'd check all the connections and even consider replacing them.
It could also be the PCM.
Old Dec 28, 2012 | 04:58 PM
frustrated dodgemom's Avatar
frustrated dodgemom
I have an 02 dodge dakota, put a pcm in it, now none of the lights work. headlites, taillites, door ding ,etc. Need help with this. Hoping its the ctm. Read here that I could unplug it along with taking the cables of battery and it would reset itself. think that will work?
Old Dec 28, 2012 | 09:29 PM
sxrsil3nt's Avatar
sxrsil3nt
Are the misfires happening on the same side of the engine?
IE: 1,3,5,7?
Could be your O2 sensors. Mine was backfiring too and I made a video (search the forums for "Backfire From Hell").
I bought the truck knowing it had this problem and it had been to the dealership 3 times and they couldn't tell it was a bad O2 sensor.
Brought it in to my mechanic and he had it solved within a few hours - was an upstream O2 sensor.
