spark plug gap
Old Dec 31, 2012 | 01:36 PM
markk96's Avatar
markk96
I will never run Autolite in my 4.7 again, I used them, my MPG went down to 11MGP, once I put Champions back in, it went up to 18.
Old Dec 31, 2012 | 01:37 PM
MadisonDakota's Avatar
MadisonDakota
Originally Posted by 00DakDan
Not in the 4.7.
3923's are for the 5.2 and 5.9. 5224's would be for the 4.7 or use the factory plugs, Champion RC12MCC4.
I have 3923 in my 4.7, and it runs just fine. With that said, I will go with the RC12MCC4 plug the next time I change them. When I installed the 3923 in my truck I was mistakenly informed that that was the right plug for my truck.
Old Dec 31, 2012 | 01:38 PM
MadisonDakota
Originally Posted by Robbadodge
I do have a compressor, and have always blown it out before plug removal on my vehicles.
As for the challenge... there are two hard pipes crossing the middle. I suppose it's just a matter of removing the bolts keeping them in place, right? Call them hoses, I guess.
Thanks for the input, you guys!
You unclip them. You're talking about the A/C lines, right? The hardest part for me was the damn transmission dipstick tube. I had to pull HARD on that thing to get it out of the way.
Old Dec 31, 2012 | 02:29 PM
98DAKAZ's Avatar
98DAKAZ
Even a wide gap will still work just not the greatest and usually your gas mileage is horrible
I was helping a neighbor replace his plugs in his PT cruiser and the plugs looked like the originally 2000 plugs the gap was monumental and unbelievable it was sparking at all boy was he embarrassed
It was bizzare that he could drive the thing with that wide a gap
With my 2.5 engine I have tried the original Bosch platinum’s Bosch copper core and Bosch iridium’s as well as the champion recommended plugs and would say I liked the original Bosch platinum’s and the Bosch iridium’s the best the champions were good my favorite were the original Bosch platinum’s they just don’t last too long is all and no longer available.
At this time I’m using the Bosch iridium’s with great results along with an Accel Hot coil and the gap at .042
Old Dec 31, 2012 | 02:50 PM
Robbadodge's Avatar
Robbadodge
Got he champion and was surprised at the low $1.99 each.
yeah, the A/C lines are what I was referring to.
I will gap to stock .035. truck runs great, why change a thing?
Thanks again!
Old Dec 31, 2012 | 03:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
On mine it's the hard heater lines I have to move, not the a/c.
Check your gap? I show .040" on the sticker under the hood.
Old Dec 31, 2012 | 03:15 PM
98DAKAZ's Avatar
98DAKAZ
I think you are correct Dan .040
my 2.5 is a stock gap of .035
What is wild is my engine being a 2.5 Jeep/AMC engine all the jeepers use the same Hot coil and a gap of .060 but this usualy cause the coil to get very hot and many a jeeper have had there coil explode on them
Old Dec 31, 2012 | 03:56 PM
Robbadodge's Avatar
Robbadodge
I'll double check the sticker, then. .040 or .045 close enough ;-)
Old Dec 31, 2012 | 05:05 PM
Tom A's Avatar
Tom A
Section Moderator
I'm scratching my head here trying to think of how a large plug gap could make a coil get hot.
Old Dec 31, 2012 | 05:23 PM
MadisonDakota
More power is required to send the spark across?
