4X4 wont engage? Advise please
Old Sep 9, 2005 | 02:06 AM
flyboy08's Avatar
flyboy08
Default 4X4 wont engage? Advise please
Just tried to engage my 4X4 and realized the 4WD light wont lite and it is obvious the diff is not engaging.
1997 V8
Are there any electrical devises that would cause this that I can look at?
Better than stuck in 4X4
TIA, Paul
Old Sep 9, 2005 | 06:42 AM
horatio102's Avatar
horatio102
Default RE: 4X4 wont engage? Advise please
You have the electronic 4wd I take it?
It's a chronic problem. And yeah, it's the transfer case module that needs to be replaced. It's like $300 at the dealer. That's the 1 item I REALLY wished that wasn't on my truck. Guess what. Mine failed a month after getting the truck.
Unfortunately you can't convert the tcase to a manual one, the only way to permanently fix the problem is to swap a completely different t-case in and pop a hole for the shifter.
I try to engage 4wd at least once a month to keep everything lubed up.
Old Sep 9, 2005 | 03:21 PM
flyboy08's Avatar
flyboy08
Default Thanks Horatio
Appreciate your reponse!
It seems to go into 4low with no problem? I just cant tell if it is engaging in 4H, except when I back up in reverse, it seems to feel as though it does.
There is no WAY to see the light indicator during day time! They really should have put an in-dash indicator in.
Anyone know where the module is located? I looked at a shop manual, but there was no section on this item?
Old Sep 11, 2005 | 10:04 PM
brian2171's Avatar
brian2171
Default RE: Thanks Horatio
I have a 2001 QC 4x4 with the electronic transfer case. My thinking is that if it goes into 4lo it should work for 4hi as well. You could jack the truck up on blocks to find out for sure right?
Old Sep 12, 2005 | 04:49 PM
yellowjacket99's Avatar
yellowjacket99
First of all, do you have electronic 4x4 flyboy? I'm not sure, but I think that will make a big difference with the help you're getting. Horatio and Brian, by electronic do you mean push button 4x4? I'm just curious if you guys are all on the same page. I don't know if that was an option in his 97.
Old Sep 12, 2005 | 09:06 PM
flyboy08's Avatar
flyboy08
Default YelloJacket99
No, I have a manual shifter. I'm thinking just the indicator light has gone out? I have the Dodge extended warranty and she goes in tomorrow for a checkup.
Old Sep 13, 2005 | 12:58 AM
horatio102's Avatar
horatio102
Default RE: YelloJacket99
AH.
Interesting. If it's a manual lever then it should go in.
By electric I mean twist-****. I like levers. Electric things break easier.
Old Sep 13, 2005 | 04:12 PM
flyboy08's Avatar
flyboy08
Default Switch and more!
Well it was in fact a switch...$103.28. In addition, my upper ball joints need replacing. So I'm told. This was suppose to be done last May from the dealer I purchased it from. $470.00 for these!
Old Sep 13, 2005 | 11:25 PM
horatio102's Avatar
horatio102
Default RE: Switch and more!
Upper ball joints, as in the recalled ones? Might check into that.
Old Sep 14, 2005 | 01:54 AM
flyboy08's Avatar
flyboy08
Default Horatio
No recall on the 97 model year. At least that's what I'm told and could'nt find it on the net either.
