2000 quad cab tranny codes from car md????
Old Jan 2, 2013 | 09:40 PM
new dodge owner's Avatar
new dodge owner
Unhappy 2000 quad cab tranny codes from car md????
can any one tell me what this means... my transmission wont shift into 3rd. can this be an easy fix such as a govenor sensor or something i can do myself.... I am mechanically inclined to do my own repairs with guidance... please help!!!
CarMDŽ Check Engine Light Analysis (Primary)
Here is the condition that caused your vehicle's "Check Engine" light to turn on.
Retrieved Diagnostic Code: P0733
Technical Definition: A/T Additional Gear Ratio Error In Third Gear
Areas to Inspect - Possible Causes:
O/D and U/D pressures less than 75 psi
O/D or U/D clutch volume indexes out of specification
O/D accumulator seals are damaged
Transmission has an internal leak (U/D seals leaking)
L/R switch valve stuck in first gear position
Condition For Setting The Code: Engine started, vehicle driven to a speed of 4-37 mph at more than 500 rpm, gear selector in 3rd Gear in Drive, and the PCM detected too much difference in the engine speed and output shaft speed.
Additional Resources
In some instances your vehicle's manufacturer may issue a Technical Service Bulletin (TSB) to address this problem. (?)
Issued TSB? TSB Not Available
