Ticka-ticka-ticka sound on start up and metalic odor
Old Jan 3, 2013 | 05:22 PM
jedi75's Avatar
jedi75
Default Ticka-ticka-ticka sound on start up and metalic odor
I have a 2000 Dakota 4.7L V8. When I start it up, there is a "ticka-ticka-ticka" sound. I can't really hear it from the inside of the cab and it's pretty soft even standing right in front of the hood. After driving for a short while, maybe 5-10 minutes, and when I step around the front of the truck, I notice a faint, metalic-ish odor. It's not real strong, but definitely noticeable. There is no fluid in my parking spot.
Any ideas?
Old Jan 3, 2013 | 05:26 PM
p38251's Avatar
p38251
check exhaust manifold bolts. Passenger rears are prone to shearing off
Old Jan 4, 2013 | 01:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub forum.
Old Jan 4, 2013 | 11:47 AM
98DAKAZ's Avatar
98DAKAZ
It could be some old gas from the last fill up just wait for the tank of gas you now have to go emty fill her up and see if it still smells.
If not you may be running a bit lean
Old Jan 6, 2013 | 12:36 AM
magnethead's Avatar
magnethead
not sure what a metallic odor is, but the ticking could be a bearing or lifter, among other things. If the ticking goes away quickly, lifter. If it takes longer to go away, bearing or otherwise.
Old Jan 6, 2013 | 02:12 AM
johnhoj's Avatar
johnhoj
Just had the same thing happen to my 2003 4.7. driver side rear exhaust manifold bold sheered off.
Old Jan 13, 2013 | 12:42 PM
EricBing's Avatar
EricBing
mine warped , the drivers side manifold, i too heard the tick after it warmed it went away cause the manifold expanded..had it replaced,,drove me nuts for a few
