2000 Dakota tail light trouble
Old Jan 9, 2013 | 12:39 PM
rauanheimo2000's Avatar
rauanheimo2000
Unhappy 2000 Dakota tail light trouble
Hello all, I have received help from this forum before that worked out well. My trouble now is my left turn signal flashes fast on my 2000 Dakota quad cab with a 4.7 Ltr, it would come and go for a month or so but now is here to stay. I have traced my wires as best I can and do not see any cuts or sarapes, when the light is flashing fast what I did notice is that both filiments in the rear brake light bulb that are flashing, I checked both the lamp, I changed it, and sockets, all look good but I found out that the third light bulb, I have not changed yet, looks like it got so hot it caused the glass to bulge out and it is real black. I also seem to have the age old trouble with my dome and dash lights others seem to have, I changed the switch cluster but still the same.
Old Jan 9, 2013 | 02:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
Check BOTH bulbs in the FRONT left turn signal, and see if they are working.
Is the brake light at normal brightness?
There are 3 connections to the bulb. One for each filament and a common ground. It's sort of like a "V" where at the two tips are the hot leads and the point is the ground. If the two connections for the brake and park filaments were "connected" by a short, then the other parking lights would also flash.
If the lights are dim, then you may have a bad ground. Power is passing through both filaments and seeking ground by the other park lights.
Pull the bulb and put a meter on it.
Old Jan 9, 2013 | 04:03 PM
rauanheimo2000
Default 2000 Dakota Tail Light Trouble
Hello, I changed the lamp, and it does it with the unit unplugged now only the left rear running light is comming on with the brake light, I am going to check it again this evening, I will keep you posted.
Old Jan 13, 2013 | 12:29 PM
EricBing's Avatar
EricBing
i had a similar prob with my 99 dak the socket overheated while asparagus hunting with hazards on, replaced socket and all is well
Old Jan 13, 2013 | 05:49 PM
bwdakrt's Avatar
bwdakrt
Behind and below the tail light you'll find a connection in the wiring harness going to the tail light. Disconnect the connection and check for rust or corrosion. If found, scrape and clean and apply a small amount of dielectric grease and reconnect. May solve your problem.
Old Jan 13, 2013 | 06:14 PM
Wes Garrett's Avatar
Wes Garrett
BWDAKRT,
"I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake."
hahahahahahahahahahahahahahahahaha soo freakin true man
Old Jan 13, 2013 | 06:29 PM
bwdakrt's Avatar
bwdakrt
Originally Posted by Wes Garrett
BWDAKRT,
Old Jan 13, 2013 | 06:39 PM
ahsnowlover's Avatar
ahsnowlover
You could also try checking your flasher relay. When I went to led bulbs for my flashers it flashed as if one of the bulbs was burned out. Replaced the relay and it fixed the problem.
