98 Dakota 5.2L No Spark
Old Jan 11, 2013 | 09:29 PM
  #21
AnthonyMo's Avatar
AnthonyMo
It seems strange the batt voltage is only showing 8v. Check your grounds and for a short, something killed that batt.
With the key turned off check for current and see if its pulling an excessive amount of power when "off" should ny be a couple hundred mils to keep the batt/ecu memory etc (guessing here)
Old Jan 13, 2013 | 01:35 PM
  #22
Nick Thill's Avatar
Nick Thill
waiting to see if the pcm fixed the issue
Old Jan 15, 2013 | 04:36 PM
  #23
Jeff Phares's Avatar
Jeff Phares
I have recieved the PCM, I will try to get this installed tomorrow evening and update.
Old Jan 18, 2013 | 10:13 AM
  #24
Jeff Phares
PCM is installed. Truck is running, however, i dont have any dash signals. The OBD reader is working now, passed all codes. The security light and low fuel light still comes on and the odometer is flashing.
any body have any ideas on the dash signals?
Old Jan 18, 2013 | 04:51 PM
  #25
Jeff Phares
Ran the Dash Test by pressing in the odometer button and turning the key on. came up with codes 920, 921, 950, and 999. Continued with the test and all the guages worked through the test sequence. From what i am reading, those 900 codes all have to do with information from the PCM. I contacted the reman PCM folks and they are sending me a new PCM.
It sounds like this was the issue, hopefully the new PCM will solve everything and have the ole dodge back on the road next week.
Old Jan 18, 2013 | 05:19 PM
  #26
98DAKAZ's Avatar
98DAKAZ
Thats great news
A question if you please how was the Dakota running before this happened?
Or did you buy it that way?
Old Jan 22, 2013 | 10:17 PM
  #27
Jeff Phares
I recieved the 2nd PCM and installed today. All is well now, she breathes again. all dash signals working now. High Praise to Auto Computer Exchange. The same day I installed the first PCM and the dash didnt work, the shipped a new one out the same day.
