Spongy Brakes
Old Jan 21, 2013 | 07:14 PM
MadisonDakota's Avatar
MadisonDakota
I replaced both front calipers a few years ago, totally forgot about doing them.
I bled just the front today, and I got a TON of bubbles out of the right front. The truck has a much better stopping bite now.
I plan on doing the rears, but that will have to wait a few more days. Thanks for the help guys.
Old Jan 22, 2013 | 12:33 AM
joe002's Avatar
joe002
Originally Posted by MadisonDakota
...I bled just the front today, and I got a TON of bubbles out of the right front...
That could be a sign the brakes are binding (or you used them a lot) and the brake fluid boiled. If you only saw it on one wheel I would look for signs of the brakes binding.
Old Jan 22, 2013 | 10:39 AM
MadisonDakota
I think it's more likely that I never bled them correctly when I first did the caliper job. I was...like 14 or 15, i've learned a lot since then.
Old Jan 22, 2013 | 12:52 PM
priceman14's Avatar
priceman14
From my experience, a lot of pedal feel does come from the rear drums, as others said. I had the rear metal brake line rust out and leak, it practically felt like I lost all pedal feel. Had a shop put a new rear line in, but they didn't quite bleed all the air out. After my Dad and I bled more air out, the brakes felt good.
Old Jan 22, 2013 | 09:01 PM
joe002's Avatar
joe002
I was giving you the benefit of the doubt - fixing a poor job bleeding the brakes is easy.
I know on one car I screwed up the install on one wheel, and the pads were always rubbing (didn’t notice) and boiled the brake fluid until I figured it out. On a newish F-250 I was towing a camper down a long hill and used the brakes too much and boiled them so at the bottom I had nothing. When I got home I had a recall notice from Ford stating that under certain circumstances the brakes my fail from overheating and bring it in for a fix (they added a insulator).
Old Jan 23, 2013 | 12:51 AM
MadisonDakota
I plan on replacing all rubber lines with braided stainless steel lines...but that's another project for another day.
Old Jan 27, 2013 | 03:35 PM
MadisonDakota
Okay, so, I planned on rebleeding/flushing everything. Started with the RR, and then the LR caused me trouble....I can't get much of anything to push out of it. What's going on?
Rear disk with RWAL.
Old Jan 27, 2013 | 04:01 PM
joe002's Avatar
joe002
Did you see any rust in the master cylinder or the lines?
Old Jan 27, 2013 | 04:42 PM
MadisonDakota
No, but I didn't really look either.
Old Jan 27, 2013 | 05:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
It is possible that the bleeder itself is defective, or clogged. Since you get fluid to the RR you should get the same on the LR.
