California exhaust??
Old Jan 15, 2013 | 09:16 PM
magnethead's Avatar
magnethead
Dynomax is the only one that doesn't have an explicit california notice, but it says "49 state EPA" instead. So they may be the same deal.
Magnaflow Direct-Fit Catalytic Converters by Car Sound are designed for easy bolt-on installation. Welding, cutting, tube bending equipment not needed. Designed to add performance while protecting the environment.
Note: These catalytic converters are no longer legal for sale in the state of California and will not be shipped to the state of California.
These SLP catalytic converters were designed specifically for low flow restriction and compact size. We recommend them for use with SLP's LS1 Tuned-Length Long-Tube Headers (Part 847-30051, 847-30052, 847-30053).
Mini converters are 409 stainless, but weigh only 2.5 lbs and measure only 11'' long. Installed, they only take up 7'' in length. PYPES cats will pass most states emissions testing procedures. However, check your local and state ordinances for installation and usage regulations.
Spun (seamless) 4'' diameter catalytic converters feature a stainless steel case that houses a high-flow ceramic core. These Pace Setter converters are great for use with high-flow exhaust systems. The overall length is approximately 10-1/2'' with a diameter of 4'' making them great for use on vehicles with limited ground clearance. Sold individually.
Flowmaster Direct-Fit Catalytic Converters are manufactured from high-quality stainless steel and are 49-state legal. Not for sale or use in California. Cannot be shipped to California addresses.
Dynatech PowerCat Catalytic Converters
Increase Your Exhaust Flow Up to 54 Percent!
Features
Superior Strength.
Stainless Steel Housing.
Quicker Lightoff due to High Thermal Conductivity.
Low Pressure Drop.
Small Housing for Space and Weight Savings.
Higher Flow Rates Compared to Stock and Most Aftermarket Converters.
Old Jan 15, 2013 | 10:22 PM
Vladek's Avatar
Vladek
this is what i have come up with so far.
magnaflow part #45006
catco part# 712006
walker part#81502
so far, these are the only ones that i have found that are 50 state or cali safe.
Old Mar 18, 2013 | 03:13 PM
godfather86's Avatar
godfather86
I just bought a truck that i guess seems to be a truck from california so it has all the emissions crap. I live in arizona and dont need all that. If i take it all of and but in a after market exhaust that is cat back will it make the cel come on
