F&R Diff and Transfer Case fluids
Old Jan 16, 2013 | 11:21 AM
Ryan Passini's Avatar
Ryan Passini
Default F&R Diff and Transfer Case fluids
2004 Dakota SLT Auto tranny.
My neighbor is taking my truck to school to do some work on it (front u joint) and he is going to do some fluids too.
I recently got the truck so I need to know what fluids to use, and weight. and how much each takes
Front Diff
Rear Diff
Transfer Case
Also, do I need to pick up any rtv sealant?
Old Jan 16, 2013 | 03:08 PM
Wes Garrett's Avatar
Wes Garrett
i would check this out https://dodgeforum.com/forum/2nd-gen...-download.html
for your case id click the 2004 FSM.. it will tell you what fluids and how much is required. it will take a little browsing, but its worth it. i have a copy for my 2000 dak, and it has been a VERY VALUABLE resource..
Old Jan 16, 2013 | 03:18 PM
Wes Garrett
for the seals on the diff's yes, its a good idea.
your fluids are as follows.......
PER THE FACTORY SERVICE MANUAL....
FRONT DIFF and REAR DIFF... SAE 75W-90 multipourpose type , GL-5 Gear Lubricant... VEHICLES EQUIPPED WITH LIMITED SLIP REQUIRE MOPAR LIMITED SLIP ADDITIVE. 4oz EVERY FLUID CHANGED, MIXED WITH GEAR LUBE
REAR END FLUID IF USED FOR TOWING ONLY, 75W-140 SYNTHETIC
TRANSFER CASE... MOPAR ATF+4 AUTO TRANS FLUID
MANUAL DIDN'T SPECIFY THE CAPACITIES.
Old Jan 16, 2013 | 04:16 PM
Ryan Passini
I planned on using Mobil 1 745w90. for the front and rear diff.
does it have to be mopar atf-4? Can I use a different brand ATF-4?
and no capacities listed in the manual? thats just stupid. thanks dodge. lol
Old Jan 16, 2013 | 04:40 PM
Wes Garrett
it an be any manufacturer variant of ATF 4 745w-xx? someone make a typeo somewhere?
Old Jan 16, 2013 | 04:54 PM
Ryan Passini
lol. my bad. i meant 75w90.
I wasnt sure if these were like hondas with their tranny fluid. Where Mopar is the best for it.
Old Jan 16, 2013 | 05:03 PM
Ryan Passini
next question.
Do they not use gaskets for the diffs? Advanced Auto shows them. not sure on the front diff as far as bolt holes. i can just count the rear as to what i need
Old Jan 16, 2013 | 05:09 PM
Wes Garrett
i would never buy fluids from a stealership.... can usually get the mopar fluids at advance auto parts, autozone, or similar stores, and for much cheaper, and its the same ****....
and with 235k on my trans, im using a bout 2 quarts lucas and 8 quarts atf
gear oil, i change every year and use and i belive its 75w-90 like yours (i dont have my maintance chart in front of me)
as for the gasket, i do belive they make one, but its good practice to use rtv with the gasket, apply it midway between generously and liberally
Old Jan 16, 2013 | 06:47 PM
sxrsil3nt's Avatar
sxrsil3nt
Now I would tell you to spend the extra 5 bucks and get the gaskets and don't turn back.
I just did both difs and yes 75w90 is what you want, also if you have an LSD make sure to put in the additive.
Problem with RTV is that it is an absolute pain in the *** to get off. Its easy to get it off the cover, just use a wire wheel but when its on the actually housing you dont wanna send crap flying.
I would use the gasket, and put a couple dabs of RTV or gasket sealant on the cover, then apply the gasket, and finally bolt it up to your difs.
Old Jan 16, 2013 | 10:47 PM
Ryan Passini
do you happen to know the capacity of the diffs?
