3.7 issues
Old Jan 21, 2013 | 08:25 AM
3.704sxt's Avatar
3.704sxt
New Member
Default 3.7 issues
Ok, so the 3.7 in my 'kota is making a werid noise. If I'm holding it at about 40-50, it makes a screaming/screeching noise. I'm guessing a vacuum leak, but does anybody know which hose to check or if it is a different problem?
Old Jan 21, 2013 | 09:58 AM
00DakDan's Avatar
00DakDan
Section Moderator
Screaming/screeching sounds more like a bearing. I'd think more of a whistle if it was a vacuum leak.
While it's doing it, does it change in relation to the gas pedal? That would affect the vacuum - floor it and vacuum drops, foot off and vacuum rises.
Old Jan 22, 2013 | 09:43 AM
3.704sxt's Avatar
3.704sxt
New Member
No, it's definetly a Vacuum issue, when i step the throttle up a little, it goes away, and when I drop the throttle a little, it goes away. and it only occurs around the higher speed, lower RPM ranges, like when it shifts into a higher gear and stays at a lower range.
