Recirculate Cabin Air '99 Dakota Sport
Old Jan 22, 2013 | 08:12 PM
Jeff_Erton's Avatar
Jeff_Erton
Default Recirculate Cabin Air '99 Dakota Sport
Hey guys, this is probably a stupid question, but I figure I may as well ask to be sure! I'm trying to figure out if there is a switch or a **** or something to switch between outside air and recirculated air in the cabin when I am heating or cooling my vehicle. I hadn't really though about it much until recently when the weather got really cold in Northern Ontario, and I'l like to recirculate the warm air in my cabin instead of constanty heating up outside air that is -30 degrees celcius!
It's a '99 Dakota Sport, 3.9L V6 Magnum, RWD, automatic.
Old Jan 22, 2013 | 09:16 PM
00DakDan's Avatar
00DakDan
Section Moderator
The only time it recirculates is when you're in Max a/c.
There is a recirc door though, vacuum operated. You could probably find a way to make it switch to recirc when you want.
Old Jan 23, 2013 | 08:52 AM
Robbadodge's Avatar
Robbadodge
You can have it on Max A/C with the heat turned up, right? I do it on my '01 all the time as it helps to reduce humidity, too. Not that you have much humidity at -30°C.
Just a thought....
Old Jan 23, 2013 | 07:55 PM
Dodgeboy77's Avatar
Dodgeboy77
from a fellow Canadian if you find a way to recirculate in the winter the inside of the windows will fog up faster than you can shake a stick from your breath. i have seen it on another vehicle where my friend had it on recirc by mistake.
Old Jan 23, 2013 | 09:32 PM
00DakDan's Avatar
00DakDan
Section Moderator
That's easy enough to fix, run max A/C and it will dehumidify the air.
Wait a minute? Isn't that what Robbadodge suggested?
Old Jan 24, 2013 | 10:51 AM
Robbadodge's Avatar
Robbadodge
Thumbs up
That is what I tried to explain. I just didn't do a good enough job.
Old Jan 24, 2013 | 11:14 AM
00DakDan's Avatar
00DakDan
Section Moderator
I was trying to be funny. You explained it perfectly well Robbadodge.
Old Jan 24, 2013 | 02:22 PM
Robbadodge's Avatar
Robbadodge
