Installing lift..
Old Feb 18, 2013 | 10:28 AM
DakCC4x4's Avatar
DakCC4x4
You MUST take the weight off the front of the truck. And yes the aftermarket keys will help as they have a little bit more off set on the key to give you a little more adjustment. I just did this lift on my truck and it might have taken an hour of two tops to do keys and blocks. You dont need a tool, just a C clamp to put a little pressure on the key to get the bolt started again. It also helps to put a floor jack under the lower control arm on that side to help get the bolt started. Th BOLT will fail before any of the other stuff as my old truck can attest. That is why you dont crank the tbars without taking the weight off the front. It will settle some after you adjust them and you may have to readjust. Best thing is to driver over some curbs or bumps to cycle the suspension afterwards to settle it then readjust.
Old Feb 18, 2013 | 11:43 AM
mmguy18's Avatar
mmguy18
If the torsion bar has been removed and not indexed to right location to put pressure back on suspension you can crank the bolt and nothing will happen. New keys supposedly or I should say new lift keys. Change the angle of the suspension greatly and put's more of a strain on the front end.
Old Feb 18, 2013 | 03:39 PM
Xxaler's Avatar
Xxaler
Just ***** that penetrating fluid on for a couple of days. It WILL loosen up. Seafoam Deep Creep works wonders.
Old Feb 19, 2013 | 08:05 AM
djd2392's Avatar
djd2392
Yeah ive been blasting those bolts with pb blaster.
Im just waiting for it to get warm enough to install it, thanks for all of your input guys
Old Mar 27, 2013 | 03:28 PM
97dakota237's Avatar
97dakota237
with a 3 inch lift would i need to put new suspension in???
Old Mar 27, 2013 | 05:37 PM
Tom A's Avatar
Tom A
Section Moderator
What 3" lift? What do you mean by "put new suspension in"?
Old Mar 28, 2013 | 12:30 PM
97dakota237
with a 3 inch suspension lift with the blocks and torsion keys would i need new suspension
Old Mar 28, 2013 | 07:31 PM
Tom A's Avatar
Tom A
Section Moderator
You don't want to lift your front end 3" with torsion keys. It will cause all your front end parts (ball joints, CV joints, tires, etc) to wear much faster and will make your truck ride like crap. 2" is as much as I would advise by that method.
If you get the kit with torsion bar keys, lift blocks, u-bolts, etc., you shouldn't need to buy anything else.
Old Mar 28, 2013 | 08:42 PM
97dakota237
thanks tom but i just figured sence im lifting my truck the sotck shocks wouldnt fit
Old Mar 28, 2013 | 10:13 PM
Tom A's Avatar
Tom A
Section Moderator
They'll fit.
