4X4 Rear Axle Offset
Old Feb 24, 2013 | 02:31 PM
  #21
dirtbiker's Avatar
dirtbiker
I think the rear sway bar was a part or the factory tow package. I have the tow package (on build sheet) and rear sway.
Old Feb 24, 2013 | 02:36 PM
  #22
Tom A's Avatar
Tom A
Section Moderator
Could be. I don't have a build sheet, but I think I have the tow package (looks like original equipment receiver hitch). Mine is also a Sport, so it might be part of that package. In any case, I found it to be pretty useless.
Old Feb 24, 2013 | 04:30 PM
  #23
dirtbiker's Avatar
dirtbiker
Yeah, I have the SXT package it's probably a part of the tow package. Anyway, I'll probably be taking my rear sway off too. I won't be towing anything with it once I get my diesel all built up
Old Feb 24, 2013 | 07:04 PM
  #24
joe002's Avatar
joe002
Looks like you got most of your answers.
Here are some items from my build sheet:
AGBP Tire and Handling Group
A64P 3.7L Eng(EKG)/5Spd M/T NV3500(DDC)
DBBC All Manual Transmissions DDC 5-Speed HD Manual Transmission
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
EKG 3.7L V6 Engine
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Front and Rear Stabilizer Bars
TXVP P265/70R16 OWL All Terrain Tires
WD1P 16X8.0 Cast Aluminum Wheels
Old Feb 25, 2013 | 12:22 PM
  #25
DakCC4x4's Avatar
DakCC4x4
On my old Nissan i even took off my front sway bar for better articulation. It did give a little more sway up front but was find if you got used to it. It almost looks like your rear axle was from under a vehicle with a more narrow frame. You can check the tightness of the u bolts on the rear end and also check the leaf spring bushings as this can cause some shift or movement.
Old Feb 25, 2013 | 12:30 PM
  #26
Custer's Avatar
Custer
Who's picture are you referring to?
Old Feb 25, 2013 | 12:37 PM
  #27
DakCC4x4's Avatar
DakCC4x4
On Joe's post on the first page. On the last pic it looks like where the spring pad and all is at, it looks like it has been moved more outside. Could just be the picture but you can see some rust on the axle tube next to it
Old Feb 25, 2013 | 09:01 PM
  #28
joe002's Avatar
joe002
My axle is fine. Unfortunately the wide angle lense can make things look distorted.
Old Feb 28, 2013 | 04:59 AM
  #29
Custer's Avatar
Custer
I looked at another 4X4 QC Dakota today and I'm seeing the same minor 3/8"-ish offset towards the right side like mine. I'm not going to worry about it anymore, in fact I only started paying attention after I Plasti-dipped my wheels.
